1994 ford bronco hard shifting after speedo went out! Help
Broncomanshane
YESSSSS! So after all the VSS was NOT bad. Somewhere along the line the previous owner had re spliced the wire amd the green wire slipped out of that heat shrink amd crimp, causing the speedo to go out. I couldnt force the aftermarket vss in to where i couldnt see o ring so i put the old back in to start trouble shooting. I went to a junk yard and pulled the wire running from vss for a buck because i was so skeptical about the corosion on mine. Used a pair of
Nice strippers and got them all snug into the shrink tube hooked it all back up with the one solid concection. So all in all i bought a new vss CONNECTOR, and pulled the green and red wire off of a junk f150 and PRESTO, shes back in full force shifting smoothly running like a beast. I did change all fuses that u guys directed me to as well just as precautionary measures
Broncomanshane
Thank you so much for your
Time help and patience and understanding of all my problems and the patience. I procrastinated and it could have been done sooner but shes back in full force and i thank you all
So much
Broncomanshane
But when i backed out of
Driveway to test drive i had a
Big puddle of
Oil, its dripping down off the tranny behind the oil pan area? Any input? Or
Start a new thread
Wdtdls
