Door locks
I have a problem that I hope I can get an answer for. I had to replace the passenger side door with a used one , it seemed simple the hook ups look right the mirror and the door glass work but now no power locks, when I started the project both sides worked. 1996 Bronco is what I am working on I have replaced the relay that is beside the column, is there any other fuses that I have missed. Thanks
Hey George:
No locks at all? Or just in the door you changed? Also, did you use the harness that came with the door? They have a history of breaking wires in the door jamb harness.
Should be an easy solution with a bit more info.
George Coleman
I used the wiring in the new door, and both locks worked before I swapped out the door now nether one works.
Ok thanks, Ill look at the diagrams tomorrow and look for fuses and other possibilities and post as soon as I can
Yo George ,
Section 01-14B: Door Lock Control System, Electronic
1996 F-150, F-250, F-350 and Bronco Workshop Manual​
DIAGNOSIS AND TESTING
Electrical Schematics​
Power Door Locks
Power Door Locks (Continued)
Remote Entry, F-Series
Remote Entry, F-Series (Continued)
Remote Entry, Bronco
Remote Entry, Bronco (Continued)
Remote Keyless Entry Module Connector C1, F-Series and Bronco
Pin Number​
Circuit​
Circuit Function​
1​
54 (LG/Y)​
Battery Power​
2​
Not Used​
3​
Not Used​
4​
Not Used​
5​
875 (BK/LB)​
Signal Ground​
6​
182 (BR/W)​
Ignition Switch Ground​
7​
Not Used​
8​
Not Used​
9​
Not Used​
10​
809 (GY/Y)​
Remote Keyless Program B​
11​
Not Used​
12​
Not Used​
13​
Not Used​
14​
Not Used​
15​
808 (W/Y)​
Remote Keyless Program A​
16​
Not Used​
Remote Keyless Entry Module Connector C2, F-Series and Bronco
Pin Number​
Circuit​
Circuit Function​
26​
1 (DB)​
Horn Relay​
25​
171 (BK/W)​
Battery Power​
24​
14 (BR)​
Parklamps Output​
23​
54 (LG/Y)​
Battery Power, Battery Saver Input​
22​
Not Used​
21​
Not Used​
14​
171 (BK/W)​
Battery Power​
13​
195 (T/W)​
Parklamps Input​
12​
705 (LG/O)​
Battery Saver Output​
11​
705 (LG/O)​
10​
54 (LG/Y)​
9​
Not Used​
8​
Not Used​
Remote Keyless Entry Module Connector C3, F-Series and Bronco
Pin Number​
Circuit​
Circuit Function​
20​
Not Used​
19​
53 (BK/LB)​
Illuminated Entry Output​
18​
118 (PK/O)​
Unlock All Doors​
17​
706 (GY)​
Door Jamb Switch​
16​
117 (PK/BK)​
Lock All Doors​
15​
57 (BK)​
Ground​
7​
Not Used​
6​
118 (PK/O)​
Unlock All Doors​
5​
120 (PK/LG)​
Door Lock Switch (Unlock)​
4​
119 (PK/Y)​
Door Lock Switch (Lock)​
3​
163 (R/O)​
Driver's Door Unlock​
2​
117 (PK/BK)​
Lock All Doors​
1​
57 (BK)​
Ground​
PROGRAM CONNECTOR (C4)
Pin No.​
Wire No. and Color​
Connects To​
1​
808 White, Yellow​
Program A​
2​
809 Gray, Yellow​
Program B​
NOTE: The C4 program connector is located near the remote entry receiver module, taped approximately 6 to 8 inches from the remote module on the wire assembly connected to the module.
tsebalj
