87 Bronco starting problem
Ichblas
Kansas City, KS
I have a intermittent problem in starting my Bronco. Sometimes you turn the key on and try starting it is totally dead. It you get out and rock the vehicle and try starting again, it starts. A mechanic said may be the ignition in the steering column? I am thinking the starter motor? Don't know where to start!
Totally dead?
No lights on the dash or anything?
If that is the case, start at battery cable connections (Both ends, at the battery and the solenoid for + and the block for-)
If it simply wont crank, listen for a click at the solenoid on the inner fender.
If there is nothing, test for voltage at the r\b on the S term of the solenoid while holding the key in crank.
If it clicks, test for voltage at the big terminal that heads to the starter (while the solenoid is engaged) If yes, head to the starter, if no test the voltage at the other big terminal (batt in) (again, while engaged)
That should get you started.
Ichblas
Ichblas
Kansas City, KS
Totally dead?
Thanks! I know where to go!!
Motech
Santa Cruz, CA:
Tilt column?
If so, next time it happens, move your column into a higher tilt position and retry it. If it cranks then, you likely have a broken ignition actuator inside the column.
bigd1948
