widetrackman
- Joined
- Oct 10, 2015
- Messages
- 4
- Reaction score
- 0
I have been told to eliminate the tamper sw which is a 163 ohm resistor is to put in a resistor as close as possible to 163 ohm, in my case 150 ohm. I am confused as where to put it. The tamper sw at the cylinder has a black/white dash wire going down the col. in a yellow shield. I have been told to put the resistor between the the dark green/white and ground but cant find where, so I cut the black/dash white wire coming from ign. tamper sw, inserted the resistor on the lower portion of bk/w wire and the other side of the resistor to a ground. Still no crank. I think I need to find the DG/W wire. BTW all the other devices in the starting circuit are ok
