Divorced 205 in Bronco?
muddrivermike
Texas Arp
Ok gang got an idea. I have 9 inch suspension lift on the bronco. Years ago I made modified spring buckets that give me and additional 4 inches with 4 inch blocks in the rear. Worked great, EXCEPT for my rear driveshaft angle. So I took it off after killing the H yoke. So my new idea. Run a divorced 205, which will allow me to drop the case a bit and decrease the shaft angle. Now theres NOTHING I cant modify or fabricate. Obviously a divorced 205 out of a mid 70s highboy has it on a crossmember which it hangs on. No big deal. Now has anyone converted a married 205 to a divorced changing the input shaft assembly? I know theres some bearing issue with that. Ill shorten my rear shaft, lengthen the front and get one from the trans to the T case. Keep in mind my truck has a Cummins with a 727. I have coming a short tailshaft,housing and fixed yoke to change the 727 over. So no problem there. So wanted to see what y'alls experience is if any with this set up. The extra 4 inches makes a huge difference for me with clearance of my 44s in the front. Plus I like being higher. Haha. Thanks ahead Mike
muddrivermike
muddrivermike
Texas Arp
Y not puda correct * shims under the spring perches to twist the sucker up to the 2 - 3* required?
My axle already has been reclocked, I repositioned the spring perches. Anymore and the pinion will be wayyyy to high. The driveshaft is well with in its degrees with the 9 inch lift. But will be out with the additional 4 inches. From research online, this should work great for me. Im just gonna save and collect the parts over time.
Motech
Santa Cruz, CA:
The couple of times I've installed clockable adapter plates to swing TC lower to straighten out drivelines after lift install was a real game changer, and certainly would be an easier mod than adding fabbing divorced mounting in such a tight space (compared to Highboy)
Could something like this work for you?
Skyjacker Transfer Case Re-Indexing Ring - IXR20K
Don't know if that's correct app, but they would.
Or...
'Nuff said. :cool:
muddrivermike
muddrivermike
Texas Arp
Or...
'Nuff said. :cool:
That would only affect the front output, not the rear output shaft. Im still deciding what to do at this point 😁
Why don,t you just get a log skidder and put your cab on it.haha
bigd1948
