ECM swap?
EJ in GA
Georgia
Can anyone tell me if the ECM from a 1990 F150 will work on a 1990 5.8 Bronco?
Only if its for the same engine. All Bronco and Truck EECs are pin'd out the same.
Thanks. I have the 5.8. If I’m correct the F150 has the 4.9
That swap woin't work for sure. There is also a difference between the 4wd and 2wd EEcs.
Call up O'reilly, they have some EECs in the catalog and are made to order and they ship out of TX.
I6 300 = 4.9L
302 and 351 Trucks have different firing orders but the Factory EFI for Ford trucks is Batch fire so technically you can put a 302 ** camshaft in the Truck 302 and not have to switch any of the injectors around.
Hopefully you can still get an O'reilly EEC. Covid has really messed up parts supplys.
Root710
