rear window seal
chaindrive
grant county, new mexico
the seal in there now is dry rotted and starting to leak.
is this a one piece seal or is it comprised of several pieces?
also, what is involved with replacing the seals on top of the tail gate where the window goes up and down.
thanks.
C
chaindrive
yes seabronc, part #4 is what I meant.
it's the rubber that's attached to the back of the shell that the window slides into.
it looks like parts #7 & 8 would just drop into the tail gate without disassembly, correct?
You might want 6, 7, and 8 left and right.  8 is a little tricky to get in and secures with a ***** in the side, you will see that when you take it out.  6 & 7 slide have hooks that slide into slots, be careful not to bend or kink them, window all the way down when doing this.
yo chaindrive,
I bought 49-9461 BACK GLASS UPPER RUN from LMC in June
39.95 & $10.75 for Delivery & Handling was delivered all bent and distorted @ left corner... heated it up in sunlight on a glass table, but could not get it in proper shape.. return it and pay $10.75 to ship back and prepay $10.75 to ship back from LMC? Nope.
local Ford dealer has same NOS for $27.00 + tax
