2000 F-250 fuel pump wires
budster 95
Pocano Mountains, northeast PA
Im working on a friends 2000 Ford F-250, feul pump is not running. Does anyone know the color for the hot wire, and ground wire, to the pump? I would like to check for 12 volts at the pump to eliminate the rest of the circiut.
Thanks, -Bud
Bronc76
I think its pink and black, (not sure which is which or what motor you have, doesn't think it matters). You may want to get schematics if possible to be on safe side.
budster 95
I got it. The pump wires are the two heavier gauge wires, pink with black tracer (hot), and brown is ground. Hooked up my meter, got the 12 volts with key on. Now to find an OEM pump at a decent price. $300! I have heard that the aftermarket pumps are garbage at $80. Thanks for the input, i appreciate it. Hope this helps someone else down the road. -Bud
Thanks, -Bud
Have you tried YOUTUBE? Seems no one is on. Just type in the address bar what you want and youtube .Then hit enter. They have alot of information their.
