headlights
Devil Dog08
philadelphia pa
hello again have a little problem adjusting my headlights on my 95 full size bronco. .how do i adjust the side to side adjust on the headlights? i found the one that makes it go up and down but how do i get it to go side to side.. the up and down adjuster looks like a littlle rod sticking straight up and all u do is turn it either way to adjust the up and down motion..thanks
Devil Dog08
Devil Dog08
philadelphia pa
There's no ***** on either side of headlight?
there is no ***** on either sids of the headlight.i cant figure it out. i even have a bronco manuel and it states nothing about side to side adjustment on the 95 bronco . there is adjustment screws for the earlier models
yo!
I got this from http://www.autozone.com
Here is the diagram w/adjust scew info, but I see it is opposite what Ford and Steve show here;
Adjusting ****** Vertical (#28, part of 13005) Location in Parts Break-Out Diagram in 92-96
Source: by Steve83 (Steve, That dirty old truck) at http://www.supermotors.net/registry/media/505310_1
http://repairguide.autozone.com/znetrgs/re...15280262f31.jpg
The headlights must be properly aimed to provide the best, safest road illumination. The lights should be checked for proper aim and adjusted as necessary. Certain state and local authorities have requirements for headlight aiming; these should be checked before adjustment is made.
Each headlight is adjusted by means of 2 screws located at the 10 o'clock and 3 o'clock positions on the headlight underneath the trim ring. Always bring each beam into final position by turning the adjusting screws clockwise so that the headlight will be held against the tension springs when the operation is completed.
Headlight adjustment may be temporarily made using a wall, as described below, or on the rear of another vehicle. When adjusted, the lights should not glare in oncoming car or truck windshields, nor should they illuminate the passenger's compartment of vehicles driving in front of you. These adjustments are rough and should always be fine-tuned by a repair shop which is equipped with headlight aiming tools. Improper adjustments may be both dangerous and illegal.
Before making any headlight adjustments, perform the following preparatory steps:
Make sure all tires are properly inflated.
Take into consideration any faulty wheel alignment or improper rear axle tracking.
Make sure there is no load in the truck other than the driver.
The truck's fuel tank should be about half full.
Make sure all lenses are clean.
To adjust:
Park the truck on a level surface, with the fuel tank no more than 1 / 2 full and with the vehicle empty of all extra cargo (unless normally carried). The vehicle should be facing a wall which is no less than 6 feet (1.8m) high and 12 feet (3.7m) wide. The front of the vehicle should be about 25 feet (7.6m) from the wall.
If this is be performed outdoors, it is advisable to wait until dusk in order to properly see the headlight beams on the wall. If done in a garage, darken the area around the wall as much as possible by closing shades or hanging cloth over the windows.
Turn the headlights ON and mark the wall at the center of each light's low beam, then switch on the "brights'' and mark the center of each light's high beam. A short length of masking tape which is visible from the front of the truck may be used. Although marking all 4 positions is advisable, marking 1 position from each light should be sufficient.
If neither beam on one side of the vehicle is working, park another like-sized truck in the exact spot where the truck was and mark the beams using the same side light on that truck. Then switch the trucks so the truck being worked on is back in the original spot. The truck must be parked no closer to or farther away from the wall than the second vehicle.
Perform the necessary repairs, but make sure the truck is not moved or is returned to the exact spot from which the lights were marked. Turn the headlights ON and adjust the beams to match the marks on the wall.
Have the headlight adjustment checked as soon as possible by a reputable repair shop.
Devil Dog08
Devil Dog08
philadelphia pa
yo!I got this from http://www.autozone.com
To adjust:
thanks miesk this was a big help .......like always thanks again
yw; also, thanks to COMCAST, which can not operate in ANY weather in da Pinies, esp. rain...I missed adding these Adjusting ***** pics in a 96
Source: by carl09..thank Carl too!
http://i183.photobucket.com/albums/x8/free...17/DSCN0098.jpg
http://i183.photobucket.com/albums/x8/free...17/DSCN0097.jpg
http://i183.photobucket.com/albums/x8/free...17/DSCN0080.jpg
http://i183.photobucket.com/albums/x8/free...17/DSCN0077.jpg
Let us know how it went and add some pics if you can.
Devil Dog08
Devil Dog08
philadelphia pa
Let us know how it went and add some pics i you are the best. thans to you and everyone on here
david@holycitytransportat
