Leaf Spring Swap on 83 fullsize bronco.
Broncoforlife
Victoria, BC
Does anyone have links for a Leaf Spring Swap on a 1983 fullsize bronco?
Or can anyone walk me through it step by step? pictres if able?
Thanks alot.
Im changing my front and rear axleand going to leafs on front.
Does anyone have links for a Leaf Spring Swap on a 1983 fullsize bronco? Or can anyone walk me through it step by step? pictres if able?
Thanks alot.
dana 60 up front?
for now;
For the front see Justshootme's info maybe JSM will add this swap here in the BZ someday
I have a few SAS/Dana 60 leaf swaps in my site below; I still need to combine em all since they are under Driveline, Differential and under Suspension...
and Dana 44 leaf swaps such as by;
Chris
If you post the model of the axle your installing, that would help. I have several pics at superford.org (link is in my profile and at Miesk5's website) of a Dana 60 front with leaf springs from an 88 F-350 into my 84 Bronco. SImply fabricate a crossmember for the front hangers, and bolt on/ weld the rear hangers to the frame. The 80-up Dana axles are on 36" centers for the leafs, which fit closely to the 80-up Bronco frame. JSM84
Cool, MiesK5 has a link or two from his site. I've seen some folks use 52"-long Chevy leaves to get more lift over the stock Ford units. I got about 4-5" lift just from the D60 SAS using stock springs. Oh yeah, there's also some info on SAS in the sticky topics of the general 80-96 bronco forum, might help you out. LEt us know how it goes, and if you run into problems. I think it's a failry easy swap using the leaf springs. JSM84
Broncoforlife
Victoria, BC
the axles i am using are from jeeps.
the back axle is welded from a 86 jeep commander
and the front has lockrights and is from a.. 80 somthing jeep
going to need to put offset rims on to fit
Yardape
Alberta
JEEP???????????
Oh my god, whats this world coming to?
msgsnprtom
