Anybody know how the wires are to be hooked up to the Main/Aux fuel switch on the dash (the switch foe the fuel gauge). The back has 5 posts and I have three wires. A black, white, and orange. Thanks
Hey getting there im having that problem too..I got a 69 EB I am trying to install the electric selector while wiring to the oem dash switch It has 6 posts . If you can id like that fax, it would be appreciated.My main problem that i am running into is the specific wiring for the dash switch. i know that Yellow/white is aux tank and the Orange is main tank. But the only orange wire that i see is the wire that goes on the main cluster ie fuel, oil,temp, volt. btw my bronco has had previous 3 owners.Are you using an electric fuel pump? I have the wiring diagram from mine the shows the correct post connection for your dash switch. My fuel gauge shows the tanks switching but I haven't gotten my aux tank to feed fuel. I think my electric tank switch took an early retiremnent on me. If you have a fax I will send it to you.
Your mail box is full so I will try to post.Hey getting there im having that problem too..I got a 69 EB I am trying to install the electric selector while wiring to the oem dash switch It has 6 posts . If you can id like that fax, it would be appreciated.My main problem that i am running into is the specific wiring for the dash switch. i know that Yellow/white is aux tank and the Orange is main tank. But the only orange wire that i see is the wire that goes on the main cluster ie fuel, oil,temp, volt. btw my bronco has had previous 3 owners.
