Bronco Chat * NEW *
admin1
Supreme Commander
Administrator
Hey everyone, check out our new chat room, there is a link up above for it called "Bronco Chat" or you can click here...
http://broncozone.com/chat/
Let me know what you guys think!
Dana
Yardape
Alberta
Thats awesome, but can't you set if up so we can use our broncozone info?
A
admin1
Supreme Commander
Administrator
If your logged in it should recognize that you are logged in and use your username, let me know if any of you are having trouble!
Dana
Yardape
Alberta
I can't get in. Says to login, then I try with my info. Says bad password
A
admin1
Supreme Commander
Administrator
Having the same problem.
OK, finally we got it fixed! We were linking it to the wrong user file, now everyone should be able to log in there or show up already logged in if they are logged in on Bronco Zone.
Everyone give it a try and let me know if you get in ok or can't get in, let all meet up to chat tonight at 9:00 Eastern / 6:00 Pacific time.
Thanks,
Dana
It still says "Bad Password" for me. I've never been able to chat on this computer, but I'm gonna try if i can get in!!! JSM84
A
admin1
Supreme Commander
Administrator
Is that when you are showing already logged in on BZ?
Dana
Dana, yes, I tried it both being logged in here at BZ and logged out here. No workie either way, JSM84
O.K., now I get the message "You must login using your "Member Account" to enter Bronco Chat. But I'm already logged in, since I'm posting this message.
swampthing
New Jersey
im getting the same thing as justshootme..and everytime i log in it takes me right back to the forum
Zachary!!! When I log out, and click on Bronco Chat, it says I have to log in. I do that, and I'm right back here on the forums page.
A
admin1
Supreme Commander
Administrator
If you try to go to the chat when your not logged in it will redirect you to log in then you have to manually go back and click on chat to be able to chat.
Dana
Yardape
Alberta
All I did was log out of BZ and relog back in, tried Danas link and works. I thought I was logged in already too. But needed to log out first.
A
admin1
Supreme Commander
Administrator
OK, we made another change here it should work for everyone now... let me know if not. If it redirects you to log in go ahead and log in then go back to the chat.
Dana
The link works now, entered "home" chat room. But I get the message "cannot create XLMHTTP instance", so I can't chat on this old 'puter. Maybe the new one will be enabled, JSM84
Root710
