2wd conversion has been talked about and most people know my opinion on that, I don't think it should be done. As far as drag racing an EB, you better lengthen the wheel base by a foot or so for stability. I think you would be better off getting a truck to do this with because you can strip everything off it and it has the length to better suit your needs. The other thing is that an EB is about as aerodynamic as a brick. Your times won't be anywhere close to what you would like because the windshield is almost flat and has no smooth back movement for the air flow. A truck will have better aerodynamics than an EB ever could dream of having. For that matter, if you are wanting to drag a Bronco, get a full size to do it with, longer wheel base, more sweeping lines and has the frame already set up for 351 power.
well it is kinda like that but i figure i would not do it now because i really started to look at it more and even though i could get the parts to do it.... I REALLY hated the way that other one looked that you sent to me with the scoop coming out of the hood it really looked ********!!!!! but thanks for the idea /emoticons/[email protected] 2x" width="20" height="20" />Just for clarification...
NEITHER of those EBs are mine, and I have never seen either of them in person.... the web is a wonderful place to find oddball pics of someone elses "projects"
Kinda like this one too....
