88 bronco ..head gasket
Lump1713
I'm gonna be buying a 88 bronco with a 302. it needs a head gasket. just wondering if its hard to do and what to do.
thanks
BroncoXLT85
Chelsea, MI
Not hard just time consuming. Make sure you have a torque wrench and clean the head and the block really good without getting sh$t in the cylinders.
L
Lump1713
Thanks alot, will have to try to attempt it
88 Bronco II
Did you replace your gasket? How did that turn out for you? I bought an 88 just a few months before you with the exact same problem. Replaced the gaskets and other than another quirky fuel problem it runs good.
Sgariffo
