Gas Gauge not working?
coupe66
The gas guage on my 74 bronco does not work on with either tank . Any ideas on if it would be the gauge or the sending units . Also would I be able to buy the rubber filler hoses for both tanks at a local parts store . Thanks Robert <)
Sending units are usually the problem, but could be connections also. Check the voltage at the connector for the sender unit. It should be around 5 to 7 volts if my memory serves me right. You should be able to get the hoses from a place like LMC Truck http://www.lmctruck.com .
There is a voltage drop (volt. regulator) attached to back of the instmt. panel. It allows 6volts only to the fuel gage & oil press.
If the oil press. gage is working, then the volt. reg. is ok.
The tank "switch-over" switch may be disconnected. (these wires can fall off)
The wire(s) may be off the gage itself as well.
Lastly, you can carefully remove the senders & test them.
K
kts75bronc
Guest
If you are talking about the hose that goes from the filler neckto the tank, I got some from NAPPA last week.
C
coupe66
I checked the switch for the tanks and it only had one wire hooked up to it . How many wires go hooked up to it . Is there a wiring diagram on line somewhere that I can look at . The switch has a few connections but no markings . Thanks Robert
C
coupe66
Thanks for the help but the back of the switch has 6 tabs to hook up to and how do I know which ones are used and where ? Does any one have a good wire diagram ? [-o< Thanks
C
coupe66
Has anybody had a chance to see how the wires to the switch are hooked up ? Or know of a good wiring diagram online to look at ? Thanks :-B
wdetzi
Old School
Here's an electrical and picture diagram from a 70 Bronco manual, hope it helps
wdetzi
Old School
Sorry about those diagrams - didn't mean to send them mega-size such that they were unreadable - I'll try again, hope it works better this time.
C
coupe66
Thanks for the wiring diagram . I found the wires under the dash just hanging there . I know my aux tank sending unit works for sure and when I install my new main tank hopefully it will work as well . Thanks Again :)>- Robert
66broncoman
im having the same problem with my 66 bronco. it says its on emptey all the time.
Hi Hotfeet.., welcome...
Yes...,  This diagram is from a 1967 Factory manual.  (assuming that's a copy of my post in the past)
His is a '70 catalog but is the same...............
msgsnprtom
