Dome light?
I want to remove my interior dome light to take out the headliner. What circuit is that so I can pull the fuse out? What other functions will I lose? Thanks, JSM84
The Dome lights get power from two places; the door jamb switches or thru the light switch, both supplied via fuse 8. Black with pink striped wire from light switch and black with light blue stripe from door jamb switches.
I belive the door jamb pin swchs. are grounds, Usually the positive side is the same fuse as the cig. lighter.
19314[/snapback]
The pin switches are not grounds, they complete the 12 V circuit, see attached.
J
Thanks for that attached diagram photo SeaBronc, I knew you had something that could help out!!! I have a hard time reading my Haynes' manual on the circuitry, even with bifocals. Seems to me like pulling out the fuse is better than just taking out the bulb. Checking with the listing for fuse #8, only other item I'll lose is the clock?
I have no idea where the alarm is hooked to, but I can disable that with the ignition switch or key pad.
Big Daddy 1995 Bronco
