There is also an axle code on the sticker behind the driver's door on the post/B-pillar. Post the code and someone will decipher it. H6=Ford 9" with 3.50:1, w/ limitedslip. The transmission code is there, too, if you want to know what type it is.
18763[/snapback]
On your 94 Bronco, the rear axle is a Ford 8.8" The code H9 = 3.55:1 gear ratio, with factory limited slip (Trac-Lok). A code I9 or 19 is the same ratio w/o L/S.I have a 94 bronco and on my B-pillar it reads a H9 axle on the sticker and a E code for the transmission. i was wondering if you knew what they are. thanks
18915[/snapback]
