93 Bronco radius/control arm question.
J
Jason
Guest
I have a 93 Bronco. I busted a radius arm a few days ago on a hunt, I removed it and ordered one from autozone. My question is a noticed a stud on the inside of the control arm, it has threads, was this used for anything? On the passenger side it has the same stud with nothing on it. Was it used for anything? Did I lose something?
Yo Jason,
WELCOME!
Our 96 is @ a son's home, so see attached diagram to pick out the location.  My eyesight is poor.
Same for Radius Arm Installation, Energy Suspension® in 80-96
Source: by Energy Suspension® via jegs.com
Was speed control, if equipped, recall work completed by a dealership. Call local dealer or register and view status @ https://owner.ford.com; or @ https://vinrcl.safercar.gov/vin/ ... have VIN ready.
The affected vehicles were previously repaired using a wiring harness that is not compatible with the vehicle circuit polarity. As a result, the fuse is located in the output circuit rather than in the intended input power feed circuit, and may not offer the intended protection in the event of an electrical short to ground. This could result in an underhood fire. Dealers will install a new wiring harness, or replace the mating electrical component. east302 provided following for his 93 "I found the recall information on alldata...didn't know it was even there so that's a plus. Mine has the updated harness with two fuses instead of one, so it looks like the recall was addressed correctly."
Use this guide by jowens1126 @ https://www.fullsizebronco.com/forum/23-technical-write-ups/457065-93-94-96-cruise-control-recalls-repair.html#post6530073
Note that the 93 recall is different that the other years.
Here is the 1993 Bronco Dealer Brochure in Google Drive @ https://drive.google.com/file/d/0B-xGWnnLeWl6cGFMTDNNcGprQTA/view
1993 Bronco Dealer Training Video via silver70 @
1993 Bronco, Venezuela Commercial @
Free registration for some wiring diagrams (86 through 96) and Technical Service Bulletins, (80 through 96), same as by Ford @ BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
Utahstroke
