84 bronco floor pan
Brian
Guest
I'm in the process of restoring an 84 Bronco. Does anyone produce a fully welded floor pan section? I have found the kits with all the piece but I would like to save the labor and have one that is already welded.
Yo Brian,
Unfortunately, no supplier nor Ford has the full pan, however MILL SUPPLY, Cleveland, OH,  Bronco Graveyard, LMC, NPD  ETC have front sections as you probably know by now.
We replaced 1/4  rust sections in our 96 with 1/4 panel patch panels from MILL SUPPLY, Cleveland, OH
They were primed and of 18 gauge steel - exact fit around wheel well arch and packaged very well for shipping which was very fast.
https://www.millsupply.com/auto-body-rust-repair-panels/ford/bronco/1984/?pa
1984 Ford Bronco Front Cab Floor Pan - Right Side Part https://www.millsupply.com/auto-body-rust-repair-panels/ford/bronco/1984/?page=3Number: 90-80-70-RH 1984 Ford Bronco Front cab floor pan - Measurement: 28" x 26" x 6" - Right Side, Passenger Side  $31.92
1984 Ford Bronco Front Cab Floor Pan - Left SidPart Number: 90-80-70-LH 1984 Ford Bronco Front cab floor pan - Measurement: 28" x 26" x 6" - Left Side, Driver Side $31.92
Repair in an 86
Source: by BigNorm (Old Desert Goat) see large images and captions @ https://www.supermotors.net/registry/501/18876-2
Repair w/ Rust Bullet® in an 86 Source: by xris
More pan repair links in my site @ http://schwimserver5.com/index.php?index=301
Sgariffo
