Jump to content
Sign in to follow this
Bronco Billy R
1996 Bronco XLT 5.8 Won't start.
Recommended Posts
Come home from work, she just died in the road. The engine turns over but won't start up. I was thinking fuel pump,  but before I get to deep I want some advice. Could it be a relay, module or the shut off switch?
Share this post
Link to post
Share on other sites
Yo Billy,
WELCOME!
I assume it cranks over well, if not let us know.
If it's a 78 Bronco, see https://jalopnik.com/heres-how-you-diagnose-an-engine-that-wont-start-1717491831
But if efi equipped, see https://troubleshootmyvehicle.com/ford/4.9L-5.0L-5.8L/how-to-troubleshoot-a-no-start-1
Best bet is that you have a mom and pop parts store that you use and they can loan you tools such as spark or fuel pressure test, etc.  I prefer mom and pop stores over AZ, etc because they usually have better maintained stuff.
Share this post
Link to post
Thanks so much for the quick reply,  that's awesome.
Sorry, it would help if I told you what I'm driving.  1996 5.8 xlt. Cranks over good just won't start.
I checked a couple of things. I can hear the fuel pump come on when I turn on the key. The shut off switch is in the correct position. I Haven't had a chance to check the spark yet, Or to see if it is getting fuel, that's my next test.
What's your advice if there is no spark?
Share this post
Link to post
Yo Billy,
YW!
For no spark, you'll  that site's troubleshooting within the efi link I posted,
Here it is https://troubleshootmyvehicle.com/ford/4.9L-5.0L-5.8L/how-to-troubleshoot-a-no-start-1
Then you'll see https://troubleshootmyvehicle.com/ford/4.9L-5.0L-5.8L/how-to-troubleshoot-a-no-start-2
Was speed control, if equipped, recall work completed by a dealership? Call local dealer or register and view status @ https://owner.ford.com; or @ https://vinrcl.safercar.gov/vin/ ...  have VIN ready.
"Summary: ON CERTAIN PICKUP TRUCKS, PASSENGER VEHICLES, SPORT UTILITY VEHICLES, AND MOTOR HOMES CHASSIS, THE SPEED CONTROL DEACTIVATION SWITCH MAY, UNDER CERTAIN CONDITIONS, LEAK INTERNALLY AND THEN OVERHEAT, SMOKE, OR BURN. THIS COULD RESULT IN AN UNDERHOOD FIRE."
To confirm3 current status, use this guide by jowens1126 @ https://www.fullsizebronco.com/forum/23-technical-write-ups/457065-93-94-96-cruise-control-recalls-repair.html#post6530073
Note that the 93 recall is different than the 94-96 recall
96 Bronco-F-Series Workshop Manual (PARTIAL) via 1996 Bronco/F-Series Workshop Manual
96 Bronco Owner's Guide, Maintenance Schedules  & Parts and Accessories by Ford @ https://www.fleet.ford.com/partsandservice/owner-manuals/
96 Bronco Dealer Brochure @ https://www.supermotors.net/registry/3549/15947-2  ... scroll down
96 Bronco Quick Tips Brochure Excerpts & some Eddie Bauer options @ http://www.supermotors.net/registry/2742/80431-2
Free registration for some wiring diagrams (partial, 86 through 96) and Technical Service Bulletins, (80 through 96) same as by Ford @ BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
Register to see most Ford dealer maintenance/repairs done @ any dealership nation-wide @ http://owner.ford.com .
Zl
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
