EFI Fuel Overview:
When the ignition is switched to the ON position, it turns the EEC Power Relay on. The EEC Power Relay provides power to the EEC-IV processor and the control side of the fuel pump relay. Power for the fuel pump is supplied through a fuse link attached to the starter solenoid (battery side). From the fuse link, current flow is through the fuel pump relay and Inertia Fuel Shutoff (IFS) switch to the fuel pump. The IFS switch is a safety device used to shut off the fuel pump in the event of a collision. If the IFS switch is "tripped," it must be reset by depressing the white or red button on the top of the switch. The fuel pump relay is controlled by the Powertrain Control Module (PCM).
When the ignition switch is turned to the ON position, the fuel pump will operate. If the ignition switch is not turned to the START position, the PCM will shut the fuel pump off after approximately one second. The PCM will operate the fuel pump when the ignition is in the START position to provide fuel while cranking.
After the engine starts, the PCM will continue to operate the fuel pump unless the engine stops, engine speed drops below 120 rpm, or the IFS switch is "tripped."
See my partially recovered Bronco web siteThanks to Mr. Schwim!
The fuel pressure regulator maintains a constant pressure drop across the injector nozzles. The regulator is referenced to intake manifold vacuum and is connected parallel to the fuel injectors and positioned on the far end of the fuel rail. Any excess fuel supplied by the pump passes through the regulator and is returned to the fuel tank via a return line.
The pressure regulator reduces fuel pressure to 39-40 psi (269-276 kPa) under normal operating conditions. At idle or high manifold vacuum condition, fuel pressure is reduced to approximately 30 psi (207 kPa).
The fuel pressure regulator is a diaphragm operated relief valve in which the inside of the diaphragm senses fuel pressure and the other side senses manifold vacuum. Normal fuel pressure is established by a spring preload applied to the diaphragm. Control of the fuel system is maintained through the EEC power relay and the EEC-IV or EEC-V control unit, although electrical power is routed through the fuel pump relay and an inertia switch. The fuel pump relay is normally located on a bracket somewhere above the Powertrain Control Module (PCM) and the inertia switch is located in the cab. The in-line fuel pump is usually mounted on a bracket at the fuel tank, or on a frame rail. Tank-mounted pumps can be either high or low-pressure, depending on the model.
The inertia switch opens the power circuit to the fuel pump in the event of a collision. Once tripped, the switch must be reset manually by pushing the reset button on the assembly. Check that the inertia switch is reset before diagnosing power supply problems to the fuel pump circuit.
danno
