What is the correct transmission fluid?
B-Co Kid
1987 B-Co ; 5.8L/351W; C6
Just replaced the trans pan;  What type of transmission fluid should I use when re-filling?  I see a lot of conflicting posts in different Ford forums, so I want to make sure I’m refilling with the correct ATF.    The transmission dipstick indicates use of Dexron II transmission fluid.
