tapping into Speed sensor
lovemy93
Hello....I need to find out where and how to tap into the speed sensor on my 93 Bronco. The new motor is in and I'm in the process of hooking up a stand alone transmission controller. My Mechanic tried to tap into the sensor on the diff. and the speedo is acting strange ,  when key is turned on the  needle jumps around . He is afraid of ruining the speedo so I thought I would check in here for some advise before going any further ….maybe there is another place to tap into ???...……..thanks in advance
Utahstroke
