engine swap question
lovemy93
Hi , I'm getting towards the end of an engine swap into my 93 bronco . The mechanic that is doing the swap for me doesn't think we will be able to get the dash gauges to work . The truck used to be a 5.0 ……….its now a 408 with EFI...….the EFI unit has its own controller as well as the E4OD transmission so I don't think the old computer is in play anymore …….I guess it wouldn't be the end of the world to add aftermarket gauges but I hate to look at a mostly dead dashboard...……..is there any way to get the dash gauges to work??.....thanks in advance
Yo 93,
The gauges don't travel through nor are controlled by the computer.
The sender's should work on the 408.  On the 408 ensure all ground straps etc are attached to block.
Some of the wiring diagrams:
Pin Number
Circuit
Circuit Function
904 (LG/R)
Charge Indicator Lamp
932 (GY/W)
High Beam Indicator Input
57 (BK)
Ground
450 (DG/LG)
Fasten Belt Indicator Input
29 (Y/W)
Fuel Level Input (with Tachometer)
6
19 (LB/R)
Instrument Cluster Illumination Input
57 (BK)
Ground
2 (W/LB)
Right Turn Input
9
648 (W/PK)
Tachometer Input Signal
10
398 (BK/Y)
Tachometer Ground (for 8 Cylinder)
784 (LB/BK)
Low Range Indicator Input
210 (LB)
4x4 Indicator Input
13
640 (R/Y)
Power Supply in RUN and START
14
16 (R/LG)
Charge Indicator Input
C1 instrument Cluster Connector
Pin Number
Circuit
Circuit Function
875 (BK/LB)
Unique Ground to Gauges
658 (PK/LG)
"Check Engine Indicator" Input
603 (DG)
Anti-lock Brake Warning Indicator Input
977 (P/W)
Not Used
6
29 (Y/W)
Fuel Level Input (Without Tachometer)
3 (LG/W)
Left Turn Input
31 (W/R)
Oil Pressure Input
9
875 (BK/LB)
10
39 (R/W)
Temperature Input
531 (DG/Y)
Brake Level Switch Input
608 (BK/Y)
Air Bag Indicator
13
640 (R/Y)
Power to Gauges, Hot in START or RUN
14
Not Used
C2 instrument Cluster Connector
BRONCO
Pin Number
Circuit
Circuit Function
54 (LG/Y)
Battery Input
676 (PK/O)
Ground
296 (W/P)
Power (Hot in RUN)
491 (O/LB)
4WABS Signal Input
530 (LG/Y)
4WABS Signal Return
6
Not Used
679 (GY/BK)
Speed Output to Instrument Cluster, Speed Control Amplifier to Powertrain Control Module, and Compass ●Speed Control won't work
Not Used
9
567 (LB/Y)
PSOM Programming Connector
10
Not Used
Not Used
Not Used
BRONCO
Pin Number
Circuit
Circuit Function
54 (LG/Y)
Battery Input
676 (PK/O)
Ground
296 (W/P)
Power (Hot in RUN)
491 (O/LB)
4WABS Signal Input
530 (LG/Y)
4WABS Signal Return
6
Not Used
679 (GY/BK)
Not Used
9
567 (LB/Y)
10
Not Used
Not Used
Not Used
In 92 through 96, the rear axle mounted VSS provides a 72,900 to 86,900 pulses per mile signal via the 4WABS module to the Programmable Speedometer/Odometer Module (PSOM) aka Speedometer/Odometer; PSOM then converts this signal to 8,000 pulses per mile. The correct PSOM vehicle speed signal to the PCM is an AC square wave that rises to 5 volts positive and drops back to 3 volts negative, with a frequency of about 120 Hz at 60 mph. That signal is sent out to the Powertrain Control Module (PCM) aka Computer or Electronic Engine Control (EEC) that controls the shifting of the Electronic 4-Speed Overdrive Transmission (E4OD) if equipped, and then to:speed control amplifier, if equipped;and overhead consoles compass/outside temperature display module, if equipped. Overhead console module uses the PSOM signal to estimate the accuracy of the outside temperature sensor that uses a high-speed counter to monitor vehicle speed to determine whether engine heat is causing erroneous readings.
See Computer Pin outs @ http://web.archive.org/web/20120118104425/http://www.oldfuelinjection.com/truckpinouts.html
lovemy93
lovemy93
thank you so much …..this is exactly what I needed...……….
Fryman22
