single wire alternator
diymirage
hey guys, i want to upgrade the alternator on my 87 351 bronco
if i get a single wire alternator, do i just run a 4 gauge wire from the stud to the starter relay and leave all the other wires hanging?
(i am plowing with this truck, and the hydraulics take a lot of juice)
thanks
I used 2 4 gauge wires off the back of the alt. 1 to the starter solenoid and 1 straight to the battery. ITs complete over ****.
x1 4ga wire of the back of a 3g alt to the starter solenoid is plenty. I got my 3g from O'reilly and its the part # used in the 1994 Mustang 5.0. fit great with the normal bracket grinding required.
diymirage
diymirage
Thanks skit, I'll look into that
(I like the idea of an off the shelf unit)
diymirage
diymirage
forgot to ask, with the 3G alternator, i do not need to hook the existing wires up?
Yes you will need to hook up the existing gray plug in the new 3g.
Sgariffo
