Ignition or starter relay ?
diymirage
Hey guys
I did my first big snow of the season yesterday and the bronco did fine
Today I went to start it and nothing happened
I can lay a screwdriver across the posts on the relay and she'll fire right up
(This is with the ignition in "run" I didn't try any other positions)
Is there an easy way to tell if my ignition switch or my starter relay is the culprit?
BMAD01
Broomfield, Co.
Sounds to me like the ignition switch might be out of adjustment or have a bad connection.  My 88 E/B was doing the same thing.  Turn the key,,, nothing...  Jump the starter relay and off we go!  Mine had a real crappy connection from the wiring harness going into the switch.  The inside of the switch looked like ass so I bought a new one.  Here is a link that should help if you find you need to replace the switch.
After I replaced the switch everything was fine until I couldn't turn the key off one day.  I had to replace the ignition lock.  All that crap was a few years ago now.  Good luck!
diymirage
diymirage
Thank you sir
It was indeed the ignition
For the time being I ran a wire from the fuss panel to a push button to the relay
I might properly fix it come spring, but this should get me through winter
Rickyb571
