Jump to content
fyreduck1921
Secondary Air Injection (smog) Pump Required?
Recommended Posts
Good Afternoon,
I am finally getting my 93 Eddie Bauer 351W / E4OD put back together. The Air pump is seized up. Where I live, the truck is not subjected to emissions testing. Can I remove the air pump and buy a different serpentine belt to fit, or do I need the air pump for the truck to run right. It is stock, except for a set of headers.
Thanks,
Steve
Share this post
Link to post
Share on other sites
 If everything else in the engine bay is in good working order then I would fix the stupid smog pump and be happy. If you already have a modify'd engine bay then I wouldn't hesitate to delete the pump. most people choose to run a new belt but if it were me I would buy a delete pulley and keep the stock size belt
btw, I don't know if removing the smog pump causes the little light on the dash to come on or not.
Share this post
Link to post
Following parts are commonly used & available via google searches:
You are looking for Thermactor Plugs, some use 5/8" by 11 by 1" SS bolts while others have welded holes closed.
Stainless Steel Thermactor Smog Plugs the holes in the back of your cylinder heads when removing the exhaust crossover tube. Comes with 2 stainless plugs and Loctite. Hex head makes installation easy when the engine is still in the vehicle.
thermactor_plugs_large.jpg?100386
TAB & TAD  Eliminator Resistor; need one 82 ohm 3 watt Resistor for each item removed, by Ryan M. But company is out of business.
https://redirect.viglink.com/?format...gr-eliminators
This will prevent the CEL from lighting and a code to be set.
A neat mod by jrichker; "...Put the resistor inside the heat shrink tubing and crimp the connectors on. I would choose the Ford pin connectors since they should plug in the TAB & TAD wiring. That way you haven't modified the wiring so it is easy to re-install the TAB & TAD solenoids if emissions testing comes to your area. 18 gauge crimp on taps..."
Read more @
https://www.stangnet.com/mustang-forums/threads/help-me-with-the-codes-i-got.796957/
Share this post
Link to post
Guest
You are commenting as a guest. If you have an account, please sign in.
Reply to this topic...
  Only 75 emoji are allowed.
