Jump to content
Sign in to follow this
diymirage
anything i need to know before i fire up the saw?
Recommended Posts
hey guys, i picked up a second top for my bronco yesterday
once i determine which one has the best seals, i will knock the glass out of the other one and make it a "summer top"
i also want to cut a hole in the roof, and then make a custom "tonneau cover" in case i get caught in the rain
so, anything i need to know before i start this project?
Share this post
Link to post
Share on other sites
Here ya go pal!
Camper Top;
Cross-Section Structure pics in 80-96; Chris said that thye metal structure is about an 1/8-3/16" thick
Source: by Chris B (Blue, bronco boy)
The steel  "roll bar" inside the factory 78-91 Bronco camper shell is glued into the fiberglass, but not bolted to the bedwalls.  All fullsize Broncos (78-96) have a steel "roll bar" integrated into the rear edge of the fiberglass camper shell. In 92, the bar was improved & extended forward so it could be retained by 2 of the bolts, and the alignment pins were moved onto the bar, pointing down into the bedrails..."
Shortened info & pics in a 91
Source: by jtg (Jackson) at
"The flat part of the top is pretty thin, how ever you can reinforce the flat section by laminating a flat section from an other top to the in side. I've done this to a couple of tops that I have shortened and it makes a big difference."
Here is some pics of a cut up top and inside laminated of a shortened top.
Painting info; 1 DO NOT use chemical stripper (I was stripping the entire truck) it's made of SMC(sheet molded compound) and the texture is sprayed on 2 Dont use a DA. You'll sand the splatter pattern off it 3 Scuff it with red scuff pads (3M) 4 Seal with epoxy primer (I used PPG DP-40) 5)Paint, but mix with the desired amount (25-30%) of flattening agent (PPG DX685 - this stuff is weird/smells bad but works; unshaken/unstirred it looks like a sticky golf ball soaking in what I perceive elephant *** would look like). Too much flattening agent and the top will become chalky after a few yews and too little makes it look funny (too glossy). My truck is the newer '98 Expedition white (paint code YZ maybe). I used PPG, DAU product line on this one. If you do this is how I mixed: Color (DAU)16oz; Hardener(DU2)16 oz; Flattener(DX685)10oz (up to 12); Reducer 1.5- 2 oz. The PPG DX685 Chart on the cut sheet is helpful on other PPG lines; Form P-162 (9/96)..."
Source: by j. r. Nice (J. R. N)
Share this post
Link to post
thought i would share this here
i came across these pics somehwere else, its not my top, but it is exactly what i am going for
Share this post
Link to post
Yo E,
Nice! Wonder If a roll bar or family friendly cage will be needed?
Share this post
Link to post
no kidding
i got a roll bar in there, and since the truck has lap belts in the stock backseat, and 3 point belts in the third row, i think got the safety part covered
im really excited to find a few people have walked this path before
cant wait to get started on it
i guess the biggest hurdle will be choosing the upholstery shop to use
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
