Jump to content
DavidMWilmes
Need help with Bronco dimensions and measurements
Recommended Posts
Posted (edited)
Oh hello! I didn't see you there. Now that I have you, I have a modeling plan for a Ford Bronco. I game on PC. After finding a Sim called BeamNG.Drive. I am deciding to make its very own Bronco. I have seen a few attempts made. But I want to get more in-depth with the 4X4. Stock, mud, trophy. Now, this isn't going to be done within a few weeks. As I'm trying to get very detailed.
So I am here to ask you, would you help to get another Bronco in a game. Even if its just a small mod/add-on. It's always nice to see.
I cant compensate you for anything just FYI. I can look at Google. Ect ect. But if you want to help get down to the nitty-gritty and have your name posted in the credits that you helped with photos, information, sound, or whatever your contribution is, that's great I can have your username or real name whatever you want in the credits. If you tell me simple things like oh its got a 5.8l or a single snippet of your truck that's great information to use so I thank you for it ahead of time but credit will be given to the folk who help with more than a handful of things or depending on the value of information I guess.
Hope this is allowed and hope everyone understands what I'm asking.
Cheers and God bless!
Edited by DavidMWilmes
Share this post
Link to post
Share on other sites
Lets Start with a 90's (more so the last FSB)
Pretty much bone stock to begin with.
First thing will be the Frame.
Photos of the frame would be nice. Dimensions, thickness, and such. ( I could just throw something together yes but I want this to be True to the Bronco name)
In the long run here, and depending how much support I can get from people.
I want to do 1 year out of every Gen of Bronco, This includes but is not limited to Bronco, Bronco 2, and our 4 door.
This is my goal. But I am doing this in my free time.
Share this post
Link to post
Posted (edited)
Yo David,
I like your project!
Let me know if any of following will help:
1992-1996 Ford BRONCO: Separate body and frame, single channel, 5 cross members, welded frame, 3.66 in. section modulus. Maximum side rail section: 6.95 x 2.12 x 0.170 in. low carbon steel.."
Frame; 92-96 Bronco
We have the 1996 XL Model 105" WB XL
Brakes
Brake Type Power
Disc - FRONT
Front Brake Rotor Diam x Thickness (in) 11.72 x 1.95
Drum - Rear
Rear Drum Diam x Width (in) 11.03 x 2.25
Brake ABS System Four-Wheel
Brake ABS System (Second Line)
Disc - Front (Yes or ) Yes
Cargo Area Dimensions
Cargo Area Length @ Floor to Seat 3 (in)
Cargo Area Length @ Floor to Seat 2 (in) 30.7
Cargo Area Length @ Floor to Console (in) - TBD -
Cargo Area Length @ Floor to Seat 1 (in) - TBD -
Cargo Volume to Seat 2 (ft³) 50.2
Cargo Volume to Seat 1 (ft³) 79.2
Cargo Box (Area) Height (in) - TBD -
Cargo Box Width @ Wheelhousings (in) 50.8
Cargo Area Width @ Beltline (in) - TBD -
Cargo Volume to Seat 4 (ft³)
Cargo Volume to Seat 3 (ft³)
Cargo Area Length @ Floor to Seat 4 (in)
Cooling System
Standard Total Cooling System Capacity (qts) 14
 Optional Total Cooling System Capacity (qts) 16
Electrical
Maximum Alternator Watts 1125
Maximum Alternator Capacity (amps) 95
Cold Cranking Amps @ 0° F (2nd)
Cold Cranking Amps @ 0° F (Primary) 850
Engine
5.0 SAE Net Horsepower @ RPM 199 @ 4000
SAE Net Torque @ RPM 270 @ 2400
Engine Type Gas V8
Displacement 5.0L/302
Fuel System EFI
Fuel System SEFI
Exterior Dimensions
Side Door Opening Width (in)
Rear Door Opening Width (in) 63.5
Rear Door Opening Height (in) 35.8
Ground Clearance, Rear (in) 7.05
Ground Clearance, Front (in) 6.8
Ground to Top of Load Floor (in) 32.3
Overhang, Rear w/bumper (in) 45.3
Overhang, Front (in) 33.6
Height, Overall (in) 74.4
Width, Max w/o mirrors (in) 79.1
Length, Overall w/rear bumper (in) 183.6
Wheelbase (in) 104.7
Step Up Height - Side (in)
Step Up Height - Front (in)
Side Door Opening Height (in)
Frame
Frame Type
92-96 Bronco frames are made of all steel channel with replaceable steel crossmembers. Separate body and frame, single channel, 5 cross members, welded frame, 3.66 in. section modulus. Maximum side rail section: 6.95 x 2.12 x 0.170 in. low carbon steel..."
Source; Standard Catalog of 4x4s
Fuel Tank
Fuel Tank Capacity, Approx (gal) 32.0
Fuel Tank Location - Rear, under cargo area  -
Interior Dimensions
Passenger Capacity 5 with front buckets
Second Hip Room (in) - TBD -
Front Hip Room (in) - TBD -
Second Head Room (in) 39.3
Second Leg Room (in) 37.7
Second Shoulder Room (in) 64.9
Front Leg Room (in) 41.2
Front Head Room (in) 41.2
Front Shoulder Room (in) 64.9
Mileage with 5.0 and E4OD, 3:55 gear ratio, manual transfer case, air conditioning
EPA Fuel Economy Est - Hwy (MPG) 17
EPA Fuel Economy Est - City (MPG) 13
Steering
Steering Ratio (:1), On Center 17
Turning Diameter - Curb to Curb (ft) 36.6
Turning Diameter - Wall to Wall (ft) 38.9
Steering Type Power
Steering Ratio (:1), At Lock
Summary
Body Style 2 Door XL
Vehicle Name Ford Bronco
Body Code 104.7" WB
Suspension
Shock Absorber Diameter - Rear (mm) 30
Suspension Type - Front Coil Spring
Suspension Type - Rear Multi-Leaf
Spring Capacity - Front (lbs)
Spring Capacity - Front (lbs) 2450
Spring Capacity - Rear (lbs) 3770
Axle Type - Front Dana 44
Axle Type - Rear Ford 8.8 Semi-Floating
Axle Capacity - Front (lbs) 3800
Axle Capacity - Rear (lbs) 3800
Axle Ratio (:1) - Front 3.55
Axle Ratio (:1) - Rear 3.55
Shock Absorber Diameter - Front (mm) 30
Shock Absorber Diameter - Rear (mm) 35
Stabilizer Bar Diameter - Front (in) 1.00
Stabilizer Bar Diameter - Rear (in) - none -
Tires
Front Tire Size P235/75R15
Rear Tire Size P235/75R15
Spare Tire Size P235/75R15
Front Tire Capacity (lbs) 1984
Rear Tire Capacity (lbs) 1984
Spare Tire Capacity (lbs) 1984
Revolutions/Mile @ 45 mph - Front 720
Revolutions/Mile @ 45 mph - Rear 680
Revolutions/Mile @ 45 mph - Spare 680
Transmission
Drivetrain 4-Wheel Drive
Trans PTO Access none
Trans Power Take Off none
Clutch Size (in) None
Our 96 XL has the optional Automatic  E4OD
Trans Description Cont. Automatic w/OD,
Transfer Case Model Borg Warner 1356 Manual w/ shift lever on floor or Auto push button
Transfer Case Power Take Off none
Transfer Case Gear Ratio (:1), Low 2.69
Transfer Case Gear Ratio (:1), High 1.00
Vehicle
Rear Door Type  - Tailgate
Weight Information
Curb Weight - Rear (lbs) 2264
Curb Weight - Front (lbs) 2323
Gross Axle Wt Rating - Rear (lbs) 3770
Gross Axle Wt Rating - Front (lbs) 2450
Gross Vehicle Weight Rating Cap (lbs) 6300
Wheels
Rear Wheel Material Styled Steel
Front Wheel Material Styled Steel
Spare Wheel Size (in) 15 x 7.5
Front & 2 Rear Wheel Size (in)
15 x 7.5
Interior Dimensions
Pictures
fullsize
Edited by miesk5
Edited many categories
Share this post
Link to post
I have the 96 Bronco Dealer Brochure with pics @ http://www.supermotors.net/registry/3549/15947-2
Such as, for example;
96broncobrochure.jpg%20alt=
96broncobrochure6.jpg%20alt=
96broncobrochure9.jpg%20alt=
FRAME IN A 96
untitled.jpg?w=480&h=480&fit=clip
More frame pics at:
http://s31.photobucket.com/user/lbronco96/media/untitled3.jpg.html
http://s31.photobucket.com/user/lbronco96/media/untitled4.jpg.html
by lilbroncoLbronco96
Our 96 XL:
Will look for more pics if needed.
GL!
Share this post
Link to post
FRAME IN A 96
More frame pics at:
Our 96 XL:
GL!
Share this post
Link to post
ebframexdims.jpgEarly Bronco;
66-77 Bronco Frame;
Share this post
Link to post
Aaaamazing Miesk5! Yes, I can use almost all of this information! Much appreciated!
Share this post
Link to post
Posted (edited)
6 hours ago, miesk5 said:
Drivetrain 4-Wheel Drive Trans PTO Access none    Trans Power Take Off none  M5OD Manual Transmission  Clutch Size (in) 11 Clutch Size (in)   Reverse Ratio (:1) 3.41 Reverse Ratio (:1) 2.18 Sixth Gear Ratio (:1)   Fifth Gear Ratio (:1) 0.80 Fifth Gear Ratio (:1)   Fourth Gear Ratio (:1) 1.00 Fourth Gear Ratio (:1) 0.71 Third Gear Ratio (:1) 1.49 Third Gear Ratio (:1) 1.00 Second Gear Ratio (:1) 2.25 Second Gear Ratio (:1) 1.54 First Gear Ratio (:1) 3.90 First Gear Ratio (:1) 2.71 Or optional Electronic Controlled E4OD Automatic
In your first post Miesk5, (Not that I need the info now) but a lot of the things have Two values
Is that for it can be within those values? for this information is it 92-96 right? just making sure!
I know the last post was of a 66, which will help me too!
Thanks, If you want your Name in the credits with this Alone, I can do that!!!!
Also is lBronco96 on these forums or no? I'd give credit since I can use hid Photobucket photos from his project.
Share this post
Link to post
I can EDIT the values tomorrow for you.  In the transmission category, for offered the M5OD manual as std and E4OD as optional.  Most Eddie Baurermodels were built with E4OD.
Same for transfer case, manual was standard, auto push button was optional.
SEE MORE in 96 Brochure, especially this page;
Share this post
Link to post
You certainly don't have to, but thanks!@!!
I just need to know which is which I guess. just so if I come across it in my writings I don't want to guess which one was which is all.
Much appreciated
Share this post
Link to post
18 hours ago, miesk5 said:
Tires
Rear Tire Order Code T7Q
Rear Tire Order Code T7W
Rear Tire Order Code T77
Spare Tire Order Code T7Q
Spare Tire Order Code T7P
Spare Tire Order Code T7W
Spare Tire Order Code T77
Front Tire Size P265/75R15
Rear Tire Size P265/75R15
Spare Tire Size P265/75R15
Front Tire Capacity (lbs) 2245
Rear Tire Capacity (lbs) 2245
Spare Tire Capacity (lbs) 2245
Revolutions/Mile @ 45 mph - Front 680
Revolutions/Mile @ 45 mph - Rear 720
Revolutions/Mile @ 45 mph - Spare 720
Rear Tire Order Code T7P
Front Tire Order Code T7Q
Front Tire Order Code T7P
Front Tire Order Code T7W
Front Tire Order Code T77
Again like this stuff,
1. i dont even know what rear tire order code means or what its for....lol
and 2. with Front tire size, P265 & P235 i just need to know which one belongs to which model/year
Share this post
Link to post
Yo David, some but as selected options shown in my last post.  We Bought our 96 XL new with standard P235 tires and standard argent style steel wheels, standard  5.0 engine, optional E4OD transmission, manual Borg Warner 1356 transfer case.  AIR conditioning is the option
Everything else on it is marked S for standard column .
bingo! Shoulda just posted our window sticker!!!  It shows as purchased standard and optional equipment
96broncoxlE40Dacmanxferautohubswindowsti
Share this post
Link to post
Yo David,
I edited the tire info etc in my post  of Saturday at 08:54 AM
all apply to our 96 XL.  Most apply to other years depending on which options the buyer chooses.
One issue is that my 96 XL tire size is now 32x11.50 x 15.
Share this post
Link to post
Sweet i really appreciated everything you've done already!!!!! i didnt notice you were on the other bronco page aswell
do you know any facebook ford or bronco groups?
Thank you so much, guys!!!!. great stuff!
ill be getting to the 78 in due time. I want a whole fleet of Ford trucks 1 of each gen pretty much!
Okay guys, here is something I need done, probably from a handful of people.
SOUND
these I will have to keep track of so that I have at least 2-3 copies of each.
Do you know of any other bronco/ford group or forums? shot me the link or tell them about my project.
I need all the help I can get.
okay for the details.
three positions- Driver seat (windows up), Engine bay, exhaust(close by not close enough that its all distorted.)
1. Cold start
2. Warm Start?
3. Starting idle
4. normal idle
I will need a decent variety of RPM sounds also
1k 2k etc as high as someone will go.
now these rpm sounds have to be held at that particular rpm for a very short amount of time in single clips.
Now I cant send you any audio equipment for this and I wish I could to get the sounds perfect.
but I can do that later honestly. So making sure there aren't people talking or background noise. Little things I should be able to cancel out... but I need just truck sounds. Also sound of the back window rolling up and then rolling down.
I can try to put the power steering pump whine noise too if someone can get it for me...
Thanks everyone!
Share this post
Link to post
Guest
You are commenting as a guest. If you have an account, please sign in.
Reply to this topic...
  Only 75 emoji are allowed.
