Replacement rear panel
nathan351
Just pulled all my carpet out and discovered that my rust is significantly worse than I expected. I've been able to find patch panels online but I'd like to just do the whole panel. Had anyone had any luck finding these?
N
nathan351
Ah okay, I'll probably just get some patch panels and section it out.
Ok, but check local yard for F series beds that may be in fairly good condition.  I have no idea of when the design changed.
N
nathan351
I've got an idea about getting a new panel from the 66-77 model and seeing if I can splice that in to fit. Not sure on the measurements yet.
Yo Nathan,
Some dimensions show bed size for early Bronco will be narrower and shorter than full size Broncos;
78-96 Bronco (Full size) Specifications (1980-1986):
Wheelbase: 104.0 in (2641mm)
Length: 180.3 in (4579 mm)  Width: 79.3 in (2014 mm)  Height: 75.5 in (1917 mm).
Cargo Area Dimensions: length (mm): 1,5801 = 62.2 inches and width between arches (mm): 1,290 = 50.78 inches Source: by motortrend.com
Following in mm;
66-67 wheelbase 92"  length 153.8"  width 69.1" height 73"
