pj31704 0 Posted March 27, 2018 Thanks for the help on previous post all. I am closing in on getting the rig back up and running. It has been in garage without running for about 2 years and wanted to be sure I covered all my bases before firing the beast up. I've just installed new fuel tank. Also will be filling tires up, changing oil and charging battery. Are there any key items I need to check before turning the key? I have never had it sit so long before, unfortunately the day job had been in the way. Thanks for any tips! Quote Share this post Link to post Share on other sites
Bully Bob 0 Posted March 27, 2018 There is a way to pump up the oil pressure prior to start but it involves R&R'ing the dizzy. OR- You can pump it up a bit by pulling the ctr. dizzy wire..., then crank the eng. a bit. You may see a flicker in the oil pressure gage. Put the wire back on & fire it up. How's the carb..? Someone should watch while cranking so as to be sure it isn' t over flowing due to a stuck float or needle-n-seat. Don't want any "fire" Quote Share this post Link to post Share on other sites
pj31704 0 Posted September 13, 2018 Thanks for the info, Will be working on this in the next week. I watched a few vids on extended storage and starting the engine...would your recommendation be to change oil before or after? I figured before, but I am starting the wonder if it would be better after oil has had a chance to warm up a little. That way I can drain all the gunk out during the change. Any advise on previous experience or thoughts? Quote Share this post Link to post Share on other sites
Bully Bob 0 Posted September 13, 2018 I don't think it much matters.., the weather is warm so I'd drain it, put in the new oil & pour a bit in the new filter (not much 'cause it sits on an angle.) & go for it. A strong charged batt. helps. Again, a helper to watch for anything unusual while cranking/starting. Quote Share this post Link to post Share on other sites
pj31704 0 Posted September 15, 2018 Thanks for all the help! Rig fired right up! I'm sure I will begin more projects in the near future. 20180915_153542.mp4 Quote Share this post Link to post Share on other sites
Bully Bob 0 Posted September 16, 2018 WOW..! Great look'n rig..!!! Sounds good...., Good job. Quote Share this post Link to post Share on other sites
