Fuel Injector size
I'm working on getting all the parts to swap my Bronco over to MAF, but before I do I'm going through and fixing whats broke. Just to make sure that when the new PCM goes in I know for a fact that everything will work. On the list of things to change/clean is to put a new set of injectors into the engine. I know the 302's came with 19 lbs/hr but did the 351w also come with 19s? Or are those 21 lbs/hr or 24s?
Another question is, are injectors color coded?
Just wanted to share that I got my MAF kit from http://www.fiveologyracing.com The Goal now is to confirm that all the wiring in the bronco is good and to fix anything wrong. Trying to do all I can to prevent any install issues with the new ECU.
Goal is to shake down the new setup and then chip tune the new MAF system.
Utahstroke
