6cyl v8 swap
Tdrrod661/2cab
Hey guys, thanks in advance for any input I can get.
I’ve been reading the archives, but I still can’t quite wrap my head around the best course of action.
I have a 170 6 cyl with 105k 3 speed on the column, I have intended on just freshening up the 6 & enjoying the bronco with its limitations. “50mph”
I only cruise, but would really like to add power steering, disc brakes & AC one day.
I am trying to figure out the advantages to some v8 engine & transmission options.
I may have a line on a 70s 302 with a c4 out of an EB.
Is there a path of least resistance concerning engine & tranny combinations?
Simple is better for me.
Thanks
Tim
Avoid EFI and Eletronic transmissions if you like to keep things simple :lol:
A 302 is a great option for a new engine. And I think you have already pick'd a good transmission that will make for a simple swap. The AOD is another option but will require some extra steps and a trasfer-case adapter.
Skitter is right..., 302 (& sometimes a 351) is the most common change-out.
I would add.., I've had 4 EB's with the V/8 along with my present '66 with the I-6 (one V/8 had the A/T)
                      You see which one I kept..!!
Just noticed this new board format wiped out the signatures..?  And, the gallery.  :eek:
Hmmmmmm....., I'm going to have to re-think how to answer these questions from now on... :ph34r:
I'll have to get back to ya......,
Long/short.., keep it the way it is with just a few mods.
Wellll..., maybe you've already discovered this ---- V/8 eng.,  pwr. steering, & discs require a very deep wallet.
For example, V/8 swap requires everything changed from radiator to driveshaft front joint. EXCEPT for the
transfer case.
For starters, I would recommend a compression/leak-down test on your I-6. Those results will give you
info. needed to move on.  (you can rent free the tools to do this test.., or have it done)
Freshening up the I-6 may be the best investment.
Disc brakes usually req. power brakes as more pressure is needed. (this also can be expensive)
Freshening up the drums, etc, would be 1/4 the price.., maybe even less.
Power steering runs approx. $800 - $1000
Fryman22
