Temperature control **** 1967 Bronco
  • Thread starter Christy Richardson
  • Start date
C
Christy Richardson
Guest
My heater control **** for the temperature when I pulled it out it came completely out how do I remove the cable so it can be replaced
Hi Christy.., welcome..!
The actual cable is a hardened steel wire so to speak. The other end is formed in a corkscrew/pig-tail type of connector.
It just slips on the actuator peg. You should be able to put it back in place.
"...control **** for the temperature"
If you're calling out the "correct" ****., this one runs out to a valve on the pass. side valve cover. These valves have
a short life in some cases soooo.., that may be the real problem here.  Other cables run to heater box. defroster, trap doors.etc.
Let me know what you find.
Fryman22
