Fiberglass fenders
N
Nick S.
Guest
What size tires would I be able to fit without having to lift the truck with fiberglass 3” or 6” bulge fenders? Looking for all options.
Wider fender's don't really let you fit a taller tire just a wider one. The factory sent out the Bronco with 10.5x31 r15's some people have even had luck running 33's with a leveling kit in the front. But in my experience you can't fit a tire wider then 10.5". But if you had a fender that was 3" wider I guess a guy could fit a tire that is ~ 12.5" wide on a 10" wide. Maybe even wider with rim that has the proper back spacing.
Just my $0.02.
Fryman22
