Jump to content
Sign in to follow this
Pooksdad66
valve cover interference with evaporator housing on 460 swap
Recommended Posts
Good morning!  Have a 79 Bronco Ranger XLT with a 351M/400.  I have a built 460 on the stand that I plan on swapping into the truck in the spring.  Since the truck is a factory A/C truck (though the compressor is missing at this time), and the 460 has tall valve covers to clear the roller rockers, it appears that there will probably be an interference issue between the evaporator box on the firewall and the valve covers on the engine.  I definitely want to keep the factory heating system, and ideally keep the A/C option open for future completion, am I going to run into a major issue wedging this monster into the engine bay?  If so, do any of you have any advice on how to go about modifying the evaporator housing as necessary to accommodate the engine?  My plan was to use the L&L engine mounts.  Would another brand of swap mount work better to allow the engine to sit a bit lower or ???
OR, fingers crossed, is this a drop in deal and I'm worrying for nothing?
Any help you can provide would be much appreciated.
Thank you!!
Edited by Pooksdad66
Share this post
Link to post
Share on other sites
Yo P,
Matt Elgie inserted a 460 in his 78 Bronco and apparently used aftermarket Mickey Thompson valve covers brand.
I think the evap and refridgerant hoses are shown in the pics.
See pic & much more info @ http://www.projectbronco.com/Technical_Articles/installing_460.htm
Lets see if I can post his pic here http://www.projectbronco.com/images/460_01.jpg
More pics @ http://www.projectbronco.com/Show_Room/showroom7.htm
See 460 swap tips @ http://www.73-79fordtrucks.com/Techtalk.htm
please fill out your Signature with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. for better responses. Click your name in right black panel in upper right;Click, My Profile
Click, Save Changes
To post a pic from your PC, TABLET, etc., just below the reply box in lower right corner, click More Reply Options
Screen will changeClick Attach This File
http://www.irfanview.com is a good free image resizer.
1979 Bronco/F Series Electrical & Vacuum Troubleshooting Manual by topsig (Ziggy) @ http://www.supermotors.net/registry/24302/83503-2
1979 Bronco Brochure (partial) @ http://broncohq.com/Broncosales/79/79salesinfo.html
1979 Ford Bronco vs. Blazer Article by Indybronco @ http://www.supermotors.net/clubs/superford/registry/1964/33114-2
Share this post
Link to post
Guest
You are commenting as a guest. If you have an account, please sign in.
Reply to this topic...
  Only 75 emoji are allowed.
