No power to ignition switch on my 88 Ford Bronco
E-CARS dude
My 88 Ford Bronco has no power to the ignition switch but the headlights work the dome light works and the power locks work no dash lights come on no windshield wipers work no radio and no heater and does not turn the vehicle over any ideas checked battery new starter solenoid and also has a new starter
Hey E, welcome,
Check the fuses and the fuse panel.  The ignition switch gets its power from a red wire with light green stripe. ( on these old trucks the wire could have been spliced by the previous owner) .   There could be a poor connection between the fuse block inner and outer halves.
Check the fuses first.
Good luck
Yo E-CARS dude,
Check fusible link M @ starter relay near battery.
Location pics in an 88
Source: by mrwp819300 at
1990-component-location-view-15112.jpg by Seattle FSB
Check for battery voltage on the two yellow wires at ignition switch. May need to adjust the ignition switch as described below.
I got same old bull shi error message about some pics .. "you are not allowed to post the images" but it didn't specify which image... this bs is getting old and shouldn't be happening here,
Fusible Link depiction; "...most fusible links have melted/charred insulation when they burn out..."
by me via
http://www.procarcare.com/icarumba/.../icar_resourcecenter_encyclopedia_lights2.asp read more there.
Repair &; Color/ Gauge sizes; "... Fusible link wire is normal wire with special insulation designed to contain the heat, spark, and melted metal when the wire burns from excessive current draw. Fusible link wire is not rated in Amperes since its characteristics are less-obvious, but it is typically 4 gauges (AWG) smaller (higher number) than the circuit it protects. Although many vehicles now use MEGA or **** fuses where older vehicles used fusible link wire, replacing older fusible links with fuses is not recommended unless the rest of the wiring is upgraded to match the newer arrangement. Never replace a fuse with fusible link wire. In an emergency, smaller-gauge wire may be temporarily substituted for fusible link wire until an appropriate repair can be made; Orange - 22ga. - 0.35mm; Gray - 20ga. - 0.5mm; Blue - - - 18ga. - 0.8mm; Black - 16ga. - 1.0mm; Gray - 14ga. - 2.0mm; Blue - 12ga. - 3.0mm; Orange - 10ga. - 5.0mm; Black - 8ga. - 8.0mm..."
If all checks out but, when you turn the key to "RUN/START" and there's no spring resistance feeling, usually the actuator is broken inside the column. The ignition switch is located on the lower part of the steering column & has slots so it can be adjusted by loosening the 2 -7/16 nuts and move it up or down, but a lot depends on what's wrong up top with some of the other parts, ie: key cylinder, lower igniton actuator and upper igniton actuator. These parts are timed so when you turn the key to RUN they all need to move forward/downward so the actuator triggers the igniton switch to start the Bronco..
Ignition Actuator & Lock Cylinder Replacement 85 to 91 by Chris B @ http://chrisb.users.superford.org/Bronco/Projects/Steering_Column/Steering_Column.html
Ignition Switch Logic Test Source: by Broncobill78 (Dave)
Let us know if you need more info.
Next time, please fill out your Signature with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. for better responses.
Fryman22
