So here is what I diagnosed so far with the driver's side window. First off, I need a motor (there's not one in there). As you can see from the pics below, someone has done a lot of work previously and it's looking pretty bad down there. I'm also thinking about getting a new switch panel (there's a couple on ebay that look to be in pretty good condition). I've also noticed that the plug for the motor to the wiring is missing. I see where the red and yellow wire is but no connector. Would you know what specific connector to get to fit into the connector I get with the new motor or do I just need to buy a new male/female connector for it? A link to a specific connector would be great!
The first pic is the connector that I'm needing (took the pic from the passenger door) and the second pic is the switch panel I'm considering replacing (you can see the exposed yellow and red wires to the right where I'm needing to plug in the motor).
