68' grinding noise
thatbroncokid
Just finished restoring the 1970 bronco, so now I have some time to start working on my 68'. Its got a 351w out of a 74 galaxy, and I think its a c4 automatic. (lol definitely an auto, just don't know what kind). After getting a new starter out of an 82' f150 since mine was shot, I started it up for the first time in probably 6 years. The sound that followed from the starter/flexplate/torque converter, was absolutely awful. I've made a youtube video showing exactly what it sounds like and hopefully somebody knows what the **** is going on with this thing, because I'm at a complete loss. I know its not the starter not disengaging, because I bridged the ignition wire to the other side of the solenoid so it stayed on after the motor was started, and it was a totally different noise. The other noise didn't go away when I did this, it was just a compound noise of grinding from different parts of the truck.
Here is the link for the video:
Thanks!
OUCH...!!
Those shiners on the flexplate gear are a clue.
I know there's several starters & it has to be the right one..., along with the flexplates number of teeth,
and, I think the bellhousing
There's auto starters & stick-shift starters. Some have longer noses.
You'll likely have to identify that trannie, then talk to  www.Advancedadaptors.com  to find out what's
needed to make these units happy hooked together.
msgsnprtom
