Origanal ride height?
Mopartink
Hi wondering if anyone knows the original space between the axle tubes and frame for a 78 bronco? Mine definitely has lift springs and I want to replace them but not sure what lift they are.. Any help would be appreciated. Thanks
Yo M,
For now, until the crew offers better information, 1978 Bronco Brochure by Indybronco (Lula Mae) at http://www.supermotors.net/clubs/superford/registry/1964/33111
Click on each page to enlarge.
This page shows Axle Ground Clearance
Next time, please fill out your Signature with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. for better responses.
In pop up,
Click, My Profile
Enter info
Click, Save Changes
To post a pic from your PC, TABLET, etc., just below the reply box in lower right corner, click More Reply Options
Screen will change
See Attach files
pick out the pic
Click Attach This File
or click, Try our advanced uploader (requires Flash 9)
Our sponsor, Jeff at the Bronco Graveyard has offered a 2% discount to members of The BroncoZone for on line orders. To get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
http://broncograveyard.com
Hi Mo..,
Un-clear.., sounds like you're wanting to replace with the same size lift..?
What is there to gain from that..?  (BTW the newer engineered leafs do offer a softer ride if that's your goal)
I can't help except suggest doing the math by using your difference in tire size -- & roof height shown in
M5,s spec. sheet above..., against the height of your roof now.
Staff online
sf66
