Yo Tom,
Inspect:
flasher in-cab fuse block.
FUSE #7
Here is the wiring diagram,
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=46699
Turn Signal Switch, aka Multi-Function Switch (MFS) Failure Causes; "...Mechanical components wear out or electrical connections are faulty; If the switch assembly is not operating properly, turn signals, hazard warning lamps, windshield wipers/washers and the headlamp beam selection may not operate properly. Related Components to Check; The switch itself, the electrical connections to the switch and the connections to each of the affected components (items such as turn signals, wipers, etc.)..." by Ford
Multi-Function Switch (MFS) Cleaning & Internal pics in a 2001 Explorer; Miesk5 NOTE, it is electrically & functionally identical to our Broncosite in 92 through 96; "...Wipe with a rag, hit with contact cleaner and an old toothbrush to clean. Regrease with dielectric grease. Save ~$80 for a new switch that will only last ~4 years..."
Source: by Electrohacker @
https://sites.google.com/site/mfs01explorer/
Multi-Function Switch (MFS) Removal & Installation in 92 through 96 by Kevin L.
https://web.archive.org/web/20070306081430/http://kevin-long.tripod.com/mfswtch.html
Multi-Function Switch (MFS), Hazard, Turn, High & Low Headlight Dimmer, Flash-to-Pass & Brake Light Testing & Wiring Diagram in 92-96; "...the MFS testing is done with connectors disconnected; it's strictly an internal test of the MFS; There is no testing for the WCM - you test the MFS, the wiper & spray motors, and the wiring. If they're good but don't operate, it has to be the WCM by elimination..."
Miesk5 NOTE; Brake Light & Turn, High & Low Headlight Dimmer, Flash-to-Pass & Hazard CKTs are a Feed-Through Circuit in Multi-Function Switch (MFS) @
http://www.supermotors.net/registry/media/225114_1
