92 bronco left front tire keeps sliding forward
rogmit
I've got a 92 ford bronco with 5.8. I've noticed lately when pulling forward or backing up the left front tire is sliding forward or backward. I didn't see a break in radius axle, the only thing I notice was my front stabilizer bushings were bad. But, I wouldn't think that would be an issue. The other thing is do the rubber bushing wear out on your rear leaf springs. Let me know what you think guys.I've got new tires on my Bronco and I don't want to wear them out.
Elmo
Forsyth Georgia
Front end shop will inspect and advise you what is bad. Then you can decide whether to fix it yourself or have them do it.
Clubcar
Portland, Maine
check out the bolts that hold your radius arm and where it all bolts to the frame.  If loose, the whole wheel assembly can move forward and backward.
Sgariffo
