E-brake needed
Auggie
Saint Augustine, FL
Okay, tick the boxes on brakes and steering...now I need an e-brake......everything from the pedal/handle to the attachments in the rear drums......there is no sign of this Bronco ever having an e-brake.
Any and all suggestions accepted as usual. I have checked BG and Tom's but no one has the complete brake system...and even if they did it would cost about $500.00!!!!!! YIKES!!!!  I am thinking scrap yards? :((
There's two holes in the left/bottom of the dash. They have nuts welded in place. (front of handle/pedal attach point)
There's two holes in the firewall to the left of the vent box. (back of attach point)
There's one hole in the floorboard (cable pass-thru hole) below the vent box.
There's three brackets on the underbelly starting under the driver seat & two more farther back. They will
have a hole(s) in them.
Toms website should have the diagram showing the location of the brackets.., & a list of the various
cables & what's needed inside the drum.
There's 3 cables needed and a fulcrum type of mechanism.., drum parts, & of course the pedal.
Ya., may be pricey new.., maybe an older ford F100 or F150 short bed will have the same set-up.
Seems I've seen the same foot pedal in those trucks.
Then there's Ebay & Craigs List possibilities.
BTW never trust the E-brake in neutral.., on an incline unless you're a fast runner..!!! [-X
(Know from experience)  (ya.., I did catch it --- [-o<  )
Auggie
Auggie
Saint Augustine, FL
Thanks Bully, and Blade I sent you a message.  I am thinking the old F150 shortbed is going to be my best bet.
