Jump to content
Sign in to follow this
DonLawson84
Anyone have a rampage soft top?
Recommended Posts
I was looking at the rampage soft top, if anyone has them any input would be helpful.
 Do the side and rear window roll up and secure to the top or zipper all the way out?
 If they do roll up, are they secure enough to drive highway speeds rolled up?
Share this post
Link to post
Share on other sites
Yo Don
Jeff's Bronco Graveyard Full Top Fasttrac Zipper Review & pic in a 94; Jeff's design is a copy of the old STC (Specialty Top Company; out of business now); "...Well, the soft top is on. It took about 2.5 hours and it looks pretty good on the Bronco at a distance. I've got to say....I'm not that impressed with it. For almost $650.00, its really cheaply made. Its made in China. Its single stiched and alot of the snaps don't line up with the snaps on the frame. The frame bows are thin walled pipe and the lengths are off by about 1-2 inches. The kit was missing a package of sheetmetal screws. As for the new and improved tailgate frame, you are supposed to take it on and off each time you exit/enter according to the instructions. I would mount the frame to the tailgate with sheetmetal screws.....but the fabric rear window is about 4" to long. There's not enough adjustment in the frame bows to adjust it. All in all, I'm disappointed with it. Someone else might like the top.....but if I had to do it over again I would just keep taking my hard top on and off..." miesk5 NOTE; Jeffcityguy wrote; Just off the Phone with Rampage, they make the top for JBG. They did say this was their own design, not a copy. No pictures that he could email, said go look at JBG's site.
Source: by lascassas_camper at Ford Bronco Zone Forums
Jeff's Bronco Graveyard Full Top Fasttrac Zipper Review & pic in a 96; "...I got a Soft top From BJY And well I am 100% happy with it. There are a few fit ment issues that i think will work out as the top loosens up. Now i have the same issues that every one has with this top, Gaps along the rails and what not, But Sice i live in FL and dont plan on useing the hard top any more, I just used some silicone caulking and sealed it with that. I just need to get some eather stripping for the rear rail, Due to two gaps right at the ends of the rear rails. well enough talking heres the bronco. They aslo had clear windows but with my front windows i think if i had clear soft top windows it wouldnt have looked right. It took about 2.5 hours to install..."
Source: by Zippo
Jeff's Bronco Graveyard Full Top Fasttrac Zipper Review & pics in an 88; Jeff's design is a copy of the old STC (Specialty Top Company; out of business now); "...I installed my new soft top from Jeffs today. All in all it went okay. A few Snags. 1. Aluminum extruded Metal was about 3/4" too long on cab. 2. They shorted me 4 sheet metal screws 3, Screws were really weak. Broke a few. 4. Fit and Finish is Good but could be better. But I still love it. I think it looks great!..."
Source: by MississippiSlim at Ford Bronco Zone Forum
Jeff's Bronco Graveyard Full Top Fasttrac Zipper Review in an 89; "...My came from JBG, packaged as a Rampage top. The fit very well, but like some have found, the weatherstripping may not be thick enough where the top sits on the bed rails..."
Source: by psmwrx
Jeff's Bronco Graveyard Full Top Fasttrac Zipper Tailgate Bar Removal in a 93; "...To remove the tailgate bar you just need to loosen the wing nut on each corner. Be sure to unload the tension on the bar before loosening the wingnut. Of course you have a bolt sticking up when it's off. I had a few arguments with it early on and broke a zipper pull, but I attribute that to the cold. It's almost as loud as no top at all but at speed you can still hold a conversation with your passenger..." by Froggmann (Ken P)
Share this post
Link to post
Yo Don,
I had to post between Tablet freezes.
I do not believe Rampage sells Bronco tops directly.
Jeff had them http://shop.broncograveyard.com/1980-1996-Ford-Bronco-Rampage-Fast-Trac-Black-Soft-Top/productinfo/35600
New
1980-96 Ford Bronco
Black Diamond Top, Tinted Windows
Detailed Description
1980-91 Bronco Fasttrac Top uses a belt rail and plastic extrusion fastening system similar to our early Bronco top. ***In addition, these tops have zip out side panels, and rear curtains which can be zipped out or rolled up.***
Black Diamond textured 20 ounce marine grade vinyl. This new material is a lot thicker and higher quality that what has previously been available.
These tops require much less drilling to install than the older snap type tops. The belt rail, which mounts to the top of the body, uses existing holes for the mounting bolts. The cab channel requires drilling to mount, but there is no drilling into the tailgate at all. There are two holes which have to be drilled into the top of the bed sides at the rear, and also, you have to drill two holes on each side for the bow mounts.
This top is a convertible top, which can be easily folded down onto the back of the Bronco. ****Of course, you can run with the sides and back curtain zipped out and just have a canopy over the back of the Bronco. ***
Seat belts will not work with 1992-96 vehicles.
1980, 1981, 1982, 1983, 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994, 1995, 1996 Ford Bronco
Share this post
Link to post
thank you, the only tops I have found are the rampage which us sold at bronco graveyard. There is also one on softoppers website. I purchased lap belt and installed them for the back seat so I can take the top off (after breaking 3 T50 impact bits, drilled the bolts out).
Share this post
Link to post
I was looking for discount codes with the graveyard, but looks like I can get the same rampage top pretty cheap at Autozone using coupons and a gift card I have.
Edited by DonLawson84
Share this post
Link to post
Ok.
Jeff at the Bronco Graveyard has offered a 2% discount to members of The BroncoZone for on line orders. To get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
3rd Brake (High Mount) Light Installation; Mounted on Spare for Soft Top, etc. in a 92; "...Find the plug under the driver side panel and "tap" into the red/green wire (make sure this is the correct wire by pressing the brake light with a tester attached.) Put wire under the carpet or the black trim at the base of the carpet to keep hidden. Than ground the black wire behind your back panel. I have an amp so i used my amp ground..."
Source: by Joe'Bronco
3rd Brake (High Mount) Light Installation for Soft Top, etc in a 96
"Since I reside in the "Peoples Republic of California" I also had to fab up the third brake light. I used an off the shelf 4 LED light ($10), a piece of lexan (I shaped to the light size) and a "L" bracket.
I used the mounting screw as the ground point and an 18 AWG direct burial wire (overkill but all I had) to complete the circuit.
I ran the wire into the paneling on the driver's side and tapped into the solid green wire at the rail to top connection.
I made this removable so I can still but the top back on." Source: by T-dogg (Mike T) at
http://www.supermotors.net/registry/4107/17255#content
Enjoy it this summer!
Share this post
Link to post
Ordered the top, shipped to home around 470.  Thanks for the information,  I will leave a review on quality and ease of install
Share this post
Link to post
Yo Don,
YW!
Ok, looking fwd to pics and your opinions.
Share this post
Link to post
I just installed mine...a used one off craigslist...
Share this post
Link to post
Yo Rob,
Looks Great!
Any installation work-arounds you did to the top?
Share this post
Link to post
Looks brand new
I spent a couple hours cleaning the frame and the vinyl...
Share this post
Link to post
Yo Rob,
Looks Great!
The only thing was cutting off about 1/2" from one of the L channels (cab alum)  that gets screwed into the cab.  Since it was used, it was already assembled...so the install was very easy.
Share this post
Link to post
So....I am needing some help. I recently had someone give me one of these, however I am missing the Rear Bow Mount and the Bow Release Bracket.  Can any one please give me some measurements so I can get some fabricated.   *I called Rampage first they do not sell hardware or these two parts separately.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
