Oil leak
nvmotogirl
Well it ran good for 5 days!
Checked the oil, it's low and dirty. Sprung a leak today. Can't see anything leaking from opening the hood. I looked around and nothing.
It's a spot on the ground just behind the front axle and it's almost dead center between the tires.
Might look under the truck tomorrow and get a better idea.
Can any of you point in to where the oil filter is on an 89 bronco II? Didn't see anything online that showed me where it is. Maybe a general idea of where to look, thanks. Waiting for daylight!
Hoping it's not the worst - where it's located at makes me think a rear seal.
Due to the condition of the oil I'm hoping it's a pan gasket.
Oil leaks are tough to find.
Usually req. the eng. to be clean-n-dry. Rear of valve covers are often a prob.
Rear seal would be further back.
You'll see the oil filter when you're under the vehicle.
Utahstroke
