1995 blowing fuel pump fuses
95broncoark
Cave City, AR
my 95 is blowing the fuel pump **** fuse soon as turn key on, any help on which wire i might start looking for a short in
Thanks  Curt
Welcome to the Zone B)
Here is the circuit diagram.  Not sure which engine you have so here are both 5.0 and 5.8
Good Luck,
PS.  You can start by popping the inertia switch or removing one wire from it to see if it still blows the fuse.  That will narrow down the search.
95broncoark
Cave City, AR
Thanks. Found it this am the plug at the fuel tank was corroded. Cleaned it and works fine. Thanks again
Isometric
