push rod length
eaglesoaring
95 full size with a stock valve train I know that the standard push rod is 7.567 the rods I have are 7.695 will this cause any problems??  And what is the best way to tourqe down the rocker arms
Elmo
Forsyth Georgia
The length may cause the valve to remain open when it should be closed. Have these push rods been used on this specifis engine before ? i tourq the rockers with a tourq wrench one bolt at a time lol.
E
eaglesoaring
no the ones that came out were a quarter inch shorter I didn't think a tenth of an inch would make that much difference and I tourqed them down one at a time too and to 25 ft lbs is that right??
Rons beast
Hey Eagle,
5.0 or 5.7?
My info tells me the stock length is 6.272 for a roller 302.
Give us the specific situation that you are working on.  Are these rods from an engine that was previously rebuilt?...are the heads changed?...other modifications? Is this the first teardown on the engine?
There can be a reason for the longer push rods, but we need to know ALL the info on the engine.
What engine?
95 Bronco-F-Series Workshop Manual by Ford
https://www.motorcraftservice.com/pubs/content/~WSSJ/~MUS~LEN/20/SSJMAIN.HTM
NOTE: For specific engine specifications, refer to Section 03-01A, Section 03-01B, or Section 03-01C, depending on which engine you are servicing.
Section 03-01B: Engines, 5.0L MFI V-8, 5.8L MFI V-8 and 5.8L MFI Lightning V-8
1995 Bronco/F-Series Workshop Manual
IN-VEHICLE SERVICE
Rocker Armhttps://www.motorcraftservice.com/pubs/content/~WSSJ/~MUS~LEN/20/SSJ31B14.HTM
Removal
  1. Remove rocker arm attaching bolt, rocker arm seat (6A528), rocker arm (6564) and rocker arm fulcrum guide (6A588).
    Item Part Number Description 1 390385 Attaching Bolt 2 6A528 Rocker Arm Seat 3 6564 Rocker Arm 4 6A588 Rocker Arm Fulcrum Guide 5 6049 Threaded Pedestal
    (Part of Cylinder Head)
Installation
  1. Apply Multi-Purpose Grease D0AZ-19584-AA or equivalent meeting Ford specification ESB-M1C93-A to the top of the valve stem, the rocker arm seat and socket.
  2. Install the rocker arm fulcrum guide, rocker arm, fulcrum and bolt. Tighten to 24-34Nm (18-25 lb-ft).
See other Component Specs @ https://www.motorcraftservice.com/pubs/content/~WSSJ/~MUS~LEN/21/SSJ31B47.HTM
E
eaglesoaring
sorry took so long to get back but its the 5.8 and the rod length is supposed to be 7.567 I think and the closest I can find is 7.523 without paying 200.00 for a set
Rons beast
Yes 5.8 has the longer push rods. assuming you have the pedestal rockers 7.567.   How are you measuring the pushrods?  Sometimes the measuring tool contacts the inner depression of the chamfered ball on the ends. This will result in an incorrect measurement.
You never explained why you have a need to replace the pushrods.
