I've got a 1992 ford bronco 5.8 liter engine. My truck started a tapping sound several months back and I was wondering if it could be the lifters or worse scenario rod bearings and if it is the lifters because I haven't had time to tear the the upper part of the engine apart and replace the lifters,could it of damaged the cam? The truck has good horsepower and great oil pressure and I hope those facts say that it is not a rod bearing problem and is their anything that I can do before I start a tear down to determine for sure is the lifters and not something else? I did some months back pull the valve cover and checked to see if a rocker arm was loose and that wasn't the problem.So,if it is the lifters I do know that I'll have to replace all of them.I was looking online at Oreilly's auto parts and they have a set of performance hydraulic lifters and I didn't know if those would be better to use or just plain old stock lifters since I'll have to replace all of them anyway and will I have to replace push rods and rockers also or can I use the ones I have? So, I would appreciate any advice.
