rear quarter panel seams
MOJIGGA
I recently replaced my rear quarter panels (the full panel).
there is a seam where the rear quarter panel and the roof post/column whatever you want to call it.
the old seams just have seam sealer in it, and i was thinking of just bondo-ing these seams and eliminating them all together.
any thoughts on this? has anyone done this before?
my fear is that this is a flex-point, and the bondo would crack the first time the quarters flex.
i attached a picture of the seam.
Rons beast
Hey Moj,
I have filled those seams in other projects.  I used a filler with short strand fiberglass for extra strength and had no problems.
That is not a seam that get much vibration or expansion, but it is a bit of a problem filling a straight seam. I use a bodyhammer and actually dimple each side of the seam very slightly, so the filler isn't trying to hold on in a straight line.
Even better if you have a mig welder, weld and grind the seam, then a light coat of polyester filler, and it will never crack.
Good luck
M
MOJIGGA
thanks for the info Ron.
i think welding it and filling it sounds like the way to go.
For Posterity;
Sail Panel (Extension Panel) Info, Image and Sources;
That's the Sail Panel as Ford describes it in Roof Cracks Repair Procedure TSB 96-20-11 by Ford for 80-96;
Roof & Pillar Cracks TSB 96-20-11 for 80-96; Cracks may appear on the roof panel or on the corner panel sheet metal near the end of the drip rail at the B pillar
Source: by Ford via Chilton
http://content.chiltonsonline.com/TSB/displayTSBHandler.ashx?assetID=37453&key=6kAUBD5BruOJf%2f3tgozUqjXM3RdbjcQqW4sVWiE%2fp2IojfpfKqM07dr61%2bQAWHtTKXFhtULpGqBYl5IK3ydFT6pv9lTd1Z6LpffJ5Ym%2fKMbfpAtCWV4OThlN53IByHI1Dkgl8wZaGWUoB1Y%2f4dX0wg%3d%3d
altho Ford doesn't list a PN for it; it is just described as "Reinforcement – Body Side Inner Panel LH & RH (Sail)
Ford also describes it as an "Extension Panel" as shown in this diagram & listing
Source: by Ford via miesk5
see it here;
http://www.partswebsite.com//stores/...sM/MC92260.gif
3. Extension panel Right
4. Lock pillar Right
Extension panel, Extension panel Left
List Price : $43.76
Your Price : $34.57
3. Extension panel Right List Price : $43.76
Your Price : $34.57
Roof & Pillar Cracks Damage
This is why the body cracks;
front of the frame is resting on the ground, and the #3 crossmember is suspended by a single point in the center. This shows just how flexy a Bronco frame in perfect condition actually is.
by Steve
Drip Rail/Roof Ditch Seam Sealing Procedure using LORD Fusor® Adhesives
Source: by LORD Corporation
http://www.lordfulfillment.com/upload/RP3000.pdf
excerpt, "
LORD Fusor® Automotive Repair Systems has developed
this repair procedure in conjunction with Ford
Motor Company and the major aftermarket refi nish
paint companies. Ford Motor Company has a Technical
Service Bulletin outlining their specifi c repair procedure
M
MOJIGGA
here are some pics.
almost forgot to snap one before i starrted welding.
M
MOJIGGA
Thanks Ron,
its best i could do what i had and my lack of knowledge with body work.
but it will work for what i need it to do!
Looks good.  Never did like that seam.  I did mine as part of a 1/4 panel replacement.
M
MOJIGGA
well you just put mine to shame..haha
i should have bent that lip up and spot welded it like you did.
geraprieto
