Tailgate won't go down
Ocelot
91 Ford Bronco, Tailgate Window will not go down. I have replaced both circuit breakers, and examined the connection to the window motor which looks good. I don't have a repair manual so I am a little lost as to what my next step should be.
Please Help.
Shadow_D
Schenectady, NY
This topic has been discussed at nausea on this forum. Please use the search function of this forum to find the answers you are seeking.
As a quick check, try pushing in on the left side of the tail gate while operating the key switch on the tailgate. If it works, then you need to adjust the latch.
Circuit diagram attached.
Sgariffo
